LoRA RFM server and client(ultrasonic sensor)
Postby kelvinswee94 » Sat Dec 16, 2017 9:07 am
I have tried to setup LoRa RFM attached with ultrasonic sensor(client) and send notification to another LoRA RFM(server).
My objective of this setup is when there is an object pass through the ultrasonic sensor, the client is able to send notification to the server.
Problem faced:
The object is detected and the notification is sent by client. But the server didn't receive anything.
Here is the client code:
#include <SPI.h>
#include <RH_RF95.h>
#define RFM95_CS 10
#define RFM95_RST 7
#define RFM95_INT 2
#define node_id "B"
// Change to 434.0 or other frequency, must match RX's freq!
#define RF95_FREQ 915.0
// Singleton instance of the radio driver
RH_RF95 rf95(RFM95_CS, RFM95_INT);
const int trigPin = 9;
const int echoPin = 8;
const int ledPin = 6;
long duration;
int distance;
int safetyDistance;
  pinMode(RFM95_RST, OUTPUT);
  digitalWrite(RFM95_RST, HIGH);
   pinMode(trigPin, OUTPUT); // Sets the trigPin as an Output
  pinMode(echoPin, INPUT); // Sets the echoPin as an Input
  pinMode(ledPin, OUTPUT);
 while (!Serial);
  delay(100);
  Serial.println("Arduino LoRa TX Test!");
  // manual reset
  digitalWrite(RFM95_RST, LOW);
  delay(10);
  delay(10);
  while (!rf95.init()) {
    Serial.println("LoRa radio init failed");
    while (1);
  Serial.println("LoRa radio init OK!");
  // Defaults after init are 434.0MHz, modulation GFSK_Rb250Fd250, +13dbM
  if (!rf95.setFrequency(RF95_FREQ)) {
    Serial.println("setFrequency failed");
    while (1);
  Serial.print("Set Freq to: "); Serial.println(RF95_FREQ);
  // Defaults after init are 434.0MHz, 13dBm, Bw = 125 kHz, Cr = 4/5, Sf = 128chips/symbol, CRC on
  // The default transmitter power is 13dBm, using PA_BOOST.
  // If you are using RFM95/96/97/98 modules which uses the PA_BOOST transmitter pin, then
  // you can set transmitter powers from 5 to 23 dBm:
  rf95.setTxPower(23, true);
int16_t packetnum = 0;  // packet counter, we increment per xmission
void loop() {
  // Clears the trigPin
  digitalWrite(trigPin, LOW);
  delayMicroseconds(2);
  // Sets the trigPin on HIGH state for 10 micro seconds
  digitalWrite(trigPin, HIGH);
  delayMicroseconds(10);
  // Reads the echoPin, returns the sound wave travel time in microseconds
  duration = pulseIn(echoPin, HIGH);
  // Calculating the distance
  distance = duration * 0.034 / 2;
  safetyDistance = distance;
  if (safetyDistance <= 10) {
    digitalWrite(ledPin, HIGH);
    Serial.print("Distance: ");
    Serial.println(distance);
    delay(1000);
    Serial.println("Sending to rf95_server");
  // Send a message to rf95_server
  String radiopacket = "data to you #";
  radiopacket += String(packetnum++);
  radiopacket += " from ";
  radiopacket += node_id;
  Serial.print("Sending ");
  Serial.println(radiopacket); delay(10);
  rf95.send((uint8_t*)(radiopacket.c_str()), radiopacket.length()+1);
  Serial.println("Waiting for packet to complete..."); delay(10);
  rf95.waitPacketSent();
  // Now wait for a reply
  uint8_t buf[RH_RF95_MAX_MESSAGE_LEN];
  uint8_t len = sizeof(buf);
  Serial.println("Waiting for reply...");
  delay(10);
  if (rf95.waitAvailableTimeout(1000))
    // Should be a reply message for us now
    if (rf95.recv(buf, &len))
      Serial.print("Got reply: ");
      Serial.println((char*)buf);
      Serial.print("RSSI: ");
      Serial.println(rf95.lastRssi(), DEC);
    else
      Serial.println("Receive failed");
  else
    Serial.println("No reply, is there a listener around?");
  else {
    digitalWrite(ledPin, LOW);
  // Prints the distance on the Serial Monitor
And here is the code for server:
#include <SPI.h>
#define RFM95_CS 10
#define RFM95_RST 7
#define RFM95_INT 2
  while (!Serial);
  delay(100);
  Serial.println("Arduino LoRa RX Test!");
  // manual reset
  delay(10);
  delay(10);
    while (1);
    while (1);
  rf95.setTxPower(23, false);
  if (rf95.available())
    // Should be a message for us now
      RH_RF95::printBuffer("Received: ", buf, len);
      Serial.print("Got: ");
      // Send a reply
      uint8_t data[] = "received with thanks";
      rf95.send(data, sizeof(data));
      Serial.println("data received");
    else
And the attachment shows the serial output for both client and server. COM 5 is server and COM 3 is client.
Anyone know what is the problem?
Thanks
kelvinswee94
Re: LoRA RFM server and client(ultrasonic sensor)
Postby kelvinswee94 » Sun Dec 17, 2017 4:24 pm
Problem solved. My LoRA RFM shield is broken.
kelvinswee94
