plz i need some clarification about the multipoint communication,to be more specific
1st Two AT commands connect and disconnect, were modified:
AT+ZV SppConnect [remote address], AT+ZV SppDisconnect [remote Node Id]
These modifications are the lowercase of (pp)?
Cuz in the point to point serial communication they are uppercase and of course the [remote Node Id] in the disconnect command is also different.
2nd in the example which is provided in the multipoint guide
Device A initiates a connection to device B using the command (AT+ZV SppConnect [address of B]); transmit and receive data according to the protocol in the bypass mode.
And then device A initiates a connection to device C: (from command mode) using the command (AT+ZV SppConnect [address of C]).
here from command mode means, that I use the EscapeSequence command (^#^$^ %) then connect to the other device without disconnecting the remote device ??
If yes; it returns an error (AT-ZV ErrConnect).
If NO. So that I have to disconnect first and then initiate the connection to the other device, in this case there is no difference between the point to point and the multipoint OR I have something missing so plz I need clarification.
