I am interested with this RF module and i am not really understand after read through the data sheet provided.
1. Since the operating voltage of this device is 2.8 – 3.4 V, is it possible i use voltage divider rule to reduce the voltage from 5v to 3.3v by using two resistor?
2. may i know this device sent and receive data in character(ASCII)?[like the moxbotix EZ-1 i'm using now?]
3. I plan to use this device for indoor purpose with obstacle like wall. Is it still can operate?
4. Anything that i should consider other than the supply voltage since i planning to use the serial transmistion to sent and receive data using micro-controller(PIC).
