RFID system
RFID system
Postby adhha_90 » Tue Dec 28, 2010 10:50 pm
Hi there...
I have a few questions about RFID system.
Q1. I'm a little bit curious about RFID. Can I use two RFID in a single system? How does it work?
Q2. Usually, the supermarket used what type of sensor? Did it RFID or just a simple sensor?
Q3. How to make a connection between the data scanned from RFID with the server @ database?
Q4. Can a single RFID scan two code at the same time?
adhha_90
Re: RFID system
Postby shahrul » Wed Dec 29, 2010 12:08 am
adhha_90 WROTE:Hi there...
A1. What two? You just use 1 RFID Reader and can use many RFID tag.
A2. Supermarket, scan product use Bar Code Reader. I think, that is not RFID. RFID can only scan in short distance.
A3. Use microcontroller, receive RFID data then process it.
A4. RFID Reader just scan 1 RFID tag at one time.
You can see example here, there is only read one-by-one RFID Tag.
Return to RFID
