by robosang » Tue Feb 15, 2011 7:56 pm
I think is obvious your connection on breadboard is having problem, check the connections referring to the schematic of that project. LCD backlight is very straight forward connection, check your voltage from voltage regulator and power supply too.
I think Cytron are using HI-TECH C for their 16F example, 18F is using C18 from Microchip. <pic.h> is the library needed by the Hi-TECH compiler to detect correct PIC model and call the correct register name and configuration bit labels. __CONFIG (0x3F32) is for configuration bits.
Not really familiar with Mikro-C, you can actually get some sample code from MikroC and look at how the call library and configure.
