SIMULATING RFID ON PROTEUS
Fri Jun 24, 2011 4:21 pm
by MAKULA
I WANT TO SIMULATE MY CIRCUIT OF RFID READ AND DISPLAY THROUGH THE PROTEUS SIMULATION SOFTWARE, BUT I DONT HAVE AN IDEA OF HOW TO IMPUT THE RFID TAGS READ BY THE RFID READER IN MY PROTEUS CIRCUIT SO THAT I CAN CHECK IF THE CIRCUIT DISPLAYS THE WANTED USERNAME THROUGH PROTEUS. CAN ANYONE WHO HAS AN IDEA SHOW ME HOW?
Re: SIMULATING RFID ON PROTEUS
Sat Jun 25, 2011 11:34 am
by robosang
Er.... it depends on which type of RFID reader you are using. Generally there are 2 types of RFID reader, the famous one uses Weigand format, and some uses UART/RS232.
If Weigand, not much help can be given.
If UART/RS232, basically is just sending the tag ID. Mostly is ASCII. I have never uses Proteus before, but if it allow you to input ASCII code or value into RX pin of PIC, you should be able to do it.
