cytronix101 WROTE:It is possible to connect an rfid into a wireless serial (RS232) adapter that can be used in door lock system so that I can pass the data to the pc wirelessly.
cytronix101 WROTE:Thanks for the suggestion,so if I used xbee then should I connect it first to max232 ic? because i will used pic16f877a then the rc6 will be the rx so that pin i will connect the rfid data but where should I connect the xbee for wireless connection?
