Same ID number captured with different card each time
Postby limhuangfu » Sat Mar 03, 2012 10:39 am
hi all,
how do i know the RFID wiegand is proper functioning?
it give me the same ID number each time with different RFID card.
Any one can give some suggestion to solve it?
limhuangfu
Re: Same ID number captured with different card each time
Postby robosang » Mon Mar 05, 2012 3:23 pm
No one knows except yourself because you are the one that do it :mrgreen:
How do you know the ID? Which RFID it give you? Every time the same considering the sequence you scan you RFID card?
Postby limhuangfu » Sat Mar 17, 2012 10:57 pm
this issue was solved by changing wrong RFID wire connection of data 1. Cytron PR25 detail description giving me the wrong info last time with using white wire instead of yellow wire for data 1 connection.......
limhuangfu
Return to RFID
