RFID RS232 to PIC18
RFID RS232 to PIC18
Postby neohimura » Tue Apr 03, 2012 7:17 pm
Hi, Since this RFID reader is using RS232, do i need a MAX232 chip to communicate with a microprocessor (PIC18F4550)? I saw your example project connection (PR8-B) but i was wondering if i can substitute it with MAX232. Thanx
neohimura
Re: RFID RS232 to PIC18
Postby shahrul » Tue Apr 03, 2012 9:29 pm
You can add MAX232 between PIC and RFID Reader. Ex here, RFID Reader.
Schematic on Cytron use different method, since because PIC never send signal to the RFID Reader.
Postby neohimura » Wed Apr 04, 2012 1:47 pm
Alright. Thanx Shahrul. :D
neohimura
Postby yasotha padmanathan » Sun Apr 22, 2012 10:17 pm
hi, im wondering like how if i dint cut the rs232 part from the wire and would like to connect to PIC. can i do it? or still i muz cut like how cytron have done it?
yasotha padmanathan
Postby Idris » Sun Apr 22, 2012 11:01 pm
Hi yasotha padmanathan,
You can connect to PIC without cutting the wire, but you need the DB9 connector.
Postby yasotha padmanathan » Mon Apr 23, 2012 12:12 pm
ok i tried connecting with db9 male connector. but still no output. Let me tell u how i connect it. from db9 male i connect pin 2 and pin 5 using the ribbon wire to the board. RX pin i didnt connect since im not transmitting anythn back to the reader. is it pin 5 still needed since the usb already has the grnd...
yasotha padmanathan
Postby Idris » Wed Apr 25, 2012 10:30 am
Do you connect with MAX232 chip?
Return to RFID
