interfacing RFID-IDR-RS232 with pic18
Postby rachel.tan » Sun Mar 03, 2013 12:11 pm
hi, i have a tag no of 0000523066, but when tag placed on the reader.
if is Write_decimal(data[i]), it gives value of 127230230230166102038230102102
if is number(data[i]), it gives value of 7000628022
why is it like that? It should've display 0000523066 right?
Im using PIC18F4520, MPlab C18.
this is my code:
#include <p18f4520.h>
#include <system4520.h>
#include <usart.h>
#include <stdio.h>
#include <delays.h>
unsigned char uart_rec(void);
unsigned char rfid_door[16]="   RFID Door    ";
unsigned char security_sys[16]=" Security System";
unsigned char place_tag[16]=" Place your tag ";
unsigned char reader[16]=" on the reader  ";
unsigned char id_no[16]={"ID:             "};
unsigned char identified[16]="User Identified ";
unsigned char unidentified[16]="User not found! ";
unsigned char access_denied[16]="Access DENIED!  ";
unsigned char opendoor[16]="  DOOR OPENED!  ";
void main(void)
   unsigned char i, database, cardid1, ID;
   unsigned char id1[10]={0,0,0,0,5,2,3,0,6,6};
   unsigned char ID1[16]={"0000523066"};
   unsigned char data[12];
   //USART INITIALISATION
   OpenUSART(USART_TX_INT_OFF &         //transmit interrupt off
   USART_RX_INT_ON &                  //receive interrupt on
   USART_ASYNCH_MODE &                  //asynchronous mode
   USART_EIGHT_BIT &                  //8-bit data
   USART_CONT_RX &                     //continuous reception
   USART_BRGH_HIGH,25);               //for baud rate 9600
   lcd_init();
   clear_screen();
   cursor_set(0,0);
   WriteS(rfid_door);
   cursor_set(1,0);
   WriteS(security_sys);
   Delay10KTCYx(100);
      clear_screen();
      cursor_set(0,0);
      WriteS(place_tag);
      cursor_set(1,0);
      WriteS(reader);
      for(i=0; i<12; i+=1)
         data[i]=uart_rec();
      clear_screen();
      cursor_set(0,0);
      WriteS(id_no);
      cursor_set(0,3);
      Write_Decimal(data[i]);
      Delay10KTCYx(255);
unsigned char uart_rec(void)         //receive uart value
   unsigned char rec_data;
   while(PIR1bits.RCIF==0);                  //wait for data
   rec_data = RCREG;
   return rec_data;               //return the data received
rachel.tan
Re: interfacing RFID-IDR-RS232 with pic18
Postby yonghui » Tue Mar 05, 2013 2:59 pm
rachel,
what is the i in data[i]. did you properly initialize the i before pass the value?
and you didnt post the subrountine number() and Write_decimal(). i dont know whether the conversion is correct or not.
Return to RFID
