cr038 with vb2010
cr038 with vb2010
Postby siti_ierah90 » Sun Apr 20, 2014 3:24 pm
hi ..
I have a problem to connect cr038 readers with vb2010 .. where I need a reader to read the tag id numbers.
Your help is greatly appreciated.
siti_ierah90
Re: cr038 with vb2010
Postby ober » Wed Apr 23, 2014 3:45 pm
what is the problem? Can you access to COM port in VB2010? How is the hardware connection?
Postby siti_ierah90 » Sat Apr 26, 2014 12:18 am
reader connection to the computer (com port) already done .. but the reader does not read the tags .. I do not know what the problem is .. maybe coding or protocol missed
siti_ierah90
Postby ober » Mon Apr 28, 2014 8:37 am
Yes, most likely is the data/command send to the reader is having problem, double check the data you send to the reader.
Return to RFID
