RFID
RFID
Postby nurulrusli » Sun May 04, 2014 3:34 pm
HELLO.. my capacitor c23 in board rfid MiFare actually broken.. did i need to buy a new one rfid or just buy the new capacitor and solder it?
nurulrusli
Re: RFID
Postby yonghui » Mon May 05, 2014 12:58 am
the board still working after the cap broke?
u know the value of the cap?
Re: RFID
Postby nurulrusli » Mon May 05, 2014 7:19 am
I not sure the value bcause the cap is too tiny. mybe the number in the cap is 106k , 74JJ0.. it will effect the board or not?
nurulrusli
Re: RFID
Postby nurulrusli » Mon May 05, 2014 7:28 am
i already done the installation for the rfid with uart, but it error.
nurulrusli
Re: RFID
Postby ober » Tue May 06, 2014 9:34 am
Are you referring to CR038 Mifare RFID Reader/Writer? If so, can you share this information?
- Can you please capture a photo of the Reader board, to show which capacitor is burnt? And how does the capacitor burn? When you power it up the 1st time? Or it actually burnt when you receive it?
- How do you interface it with your computer/laptop? Using UC00A? Have you install the driver for it? Also it will be good if you can share the hardware setup photo with the USB to UART converter and also the reader.
- Have you check the com port number?
Re: RFID
Postby nurulrusli » Tue May 06, 2014 1:55 pm
yup..i referring the reader step.. my com port is 4. actually my capacitor is not burn but it is broke, i already instal the driver, but am nt too sure..
rfid with uart
broken capacitor
com port
driver?
nurulrusli
Re: RFID
Postby ober » Tue May 06, 2014 9:23 pm
It seem to be correct. Please do fill in the support form and our technical team will follow up with you.http://www.cytron.com.my/support.php
Re: RFID
Postby lantran » Tue Dec 06, 2016 12:42 pm
lantran
Return to RFID
