Wiegand RFID reader with arduino
Posted: Tue Nov 11, 2014 8:47 pm
Hi, I'm still new to arduino. I got a problem with this wiegand reader when using Arduino Mega. I attached the program that I copypasted (and edited abit). I suspect my problem is the MEGA did not received the signal from the reader. Can anyone help me with this?
- CODE: SELECT_ALL_CODE
#define DATA0 20
#define DATA1 21
#define MAX_BITS 100 // max number of bits
#define WEIGAND_WAIT_TIME 3000 // time to wait for another weigand pulse.
unsigned char databits[MAX_BITS]; // stores all of the data bits
unsigned char bitCount; // number of bits currently captured
unsigned char flagDone; // goes low when data is currently being captured
unsigned int weigand_counter; // countdown until we assume there are no more bits
unsigned long facilityCode=0; // decoded facility code
unsigned long cardCode=0; // decoded card code
// interrupt that happens when INTO goes low (0 bit)
void ISR_INT0()
Serial.print("0"); //to check wether the interupt works or not
bitCount++;
flagDone = 0;
weigand_counter = WEIGAND_WAIT_TIME;
// interrupt that happens when INT1 goes low (1 bit)
void ISR_INT1()
Serial.print("1"); //to check wether the interupt works or not
databits[bitCount] = 1;
bitCount++;
flagDone = 0;
pinMode(DATA0, INPUT); //green wire or wiegand reader
pinMode(DATA1, INPUT); //white wire or wiegand reader
Serial.println("put your card");
// binds the ISR functions to the falling edge of INTO and INT1
attachInterrupt(2, ISR_INT0, FALLING);
attachInterrupt(3, ISR_INT1, FALLING);
// This waits to make sure that there have been no more data pulses before processing data
if (!flagDone) {
if (--weigand_counter == 0)
flagDone = 1;
// if we have bits and we the weigand counter went out
if (bitCount > 0 && flagDone)
unsigned char i;
Serial.print("Read");
Serial.print(bitCount);
Serial.print("bits. ");
if (bitCount == 26)
// standard 26 bit format
// facility code = bits 2 to 9
for (int i=1; i<9; i++)
facilityCode <<=1;
facilityCode |= databits[i];
// card code = bits 10 to 23
for (int i=9;i<25; i++)
cardCode <<=1;
cardCode |= databits[i];
Serial.print("FC = ");
Serial.print(facilityCode);
Serial.print(", CC = ");
Serial.println(cardCode);
else
// if not 26 bit wiegand reader, it wll display comment below
Serial.println("No Card Detected");
