Servo Wheel
Mini, Nylon, Servo, Omni, Transwheel, Tank Track, Tamiya Tire......
Servo Wheel
Postby sysysy » Fri Dec 24, 2010 12:17 am
Reason to buy:
Nylon Wheel too expensive and i am not able to afford it.
And i have 2 SPG30 motor edi... so not going to buy a whole set.
Thx.
Regards,
sysysy
sysysy
Re: Servo Wheel
Postby hyng » Fri Dec 24, 2010 9:51 am
Yes, you can use the servo wheel for your SPG30 motor. However you need a coupling so that this two can joint together. The coupling is at this site
http://www.cytron.com.my/viewProduct.ph ... BlZLmD/Dc=
So, it is basically like this when you are assembling them.
DC motor --> Coupling --> Servo Wheel
Re: Servo Wheel
Postby sysysy » Tue Dec 28, 2010 3:10 pm
May i know what is the function of castor and muz use that for the project?
sysysy
Re: Servo Wheel
Postby shiyan » Tue Dec 28, 2010 10:06 pm
sysysy wrote:May i know what is the function of castor and muz use that for the project?
Normally castor is for supporting. If you don need it don use it.
shiyan
Re: Servo Wheel
Postby khushivis » Sat Aug 17, 2013 3:51 pm
It is good wheel for vehicle
khushivis
Re: Servo Wheel
Postby lotorax » Mon Jul 10, 2017 1:21 pm
Yes, this wheel is very useful
I want to became game developer so I need to learn all this technial stuff for that
lotorax
Return to Wheel, Tire and Track
