Controlling SC08A with an Arduino
Postby athyabm » Tue Apr 24, 2012 12:51 pm
Hi there, I need some help controlling servo motors via the SC08A Servo Controller using an Arduino Duemilanove.
I used the manual where you simply send binary numbers that determine the servo position, speed, etc.
But however, it doesn't seem to work as expected.
Can anybody please help?
athyabm
Re: Controlling SC08A with an Arduino
Postby shahrul » Tue Apr 24, 2012 2:03 pm
Just send serial.
//turn on
Serial.write((byte)0xC0);
Serial.write((byte)0x01);
//then control servo
Serial.write((byte)0xE1);
Serial.write((byte)0x7F);
Serial.write((byte)0x3F);
Serial.write((byte)0x00);
Postby athyabm » Wed Apr 25, 2012 7:48 am
thank u shahrul for t reply.
so do we have to put in a hexadecimal number as the 'byte'?
i was using decimal all this time. no wonder it wasnt working lol
athyabm
Postby shahrul » Wed Apr 25, 2012 11:56 am
It's dos't matter with hexadecimal or decimal or binary.
You can write 0xC0 (in hex) or 192 (in dec) or 0b11000000 (in binary). All the serial out is still same.
Postby athyabm » Wed Apr 25, 2012 5:02 pm
Ok.
I'm connecting a small servo to open and close the robot gripper as shown
http://cytron.com.my/viewProduct.php?pc ... %20Gripper
and
another servo to rotate the whole gripper through an angle of 180 degrees
http://cytron.com.my/viewProduct.php?pc ... vo%20Motor
could you pls tell me a suitable voltage to apply across the sc08a controller
here are a few video demos of t gripper
http://www.youtube.com/watch?v=m_vvW6ZqJnI
http://www.youtube.com/watch?v=9K6puD1OqH8
http://www.youtube.com/watch?v=XAOTlNAqqwQ
athyabm
Postby shahrul » Wed Apr 25, 2012 5:34 pm
The video looks servo can run, what's the problem?
You can use voltage 5V with high amp capability, not from USB or Arduino source.
I use voltage regulator 7805 can drive 4 servo, see example here Servo Controller.
Postby athyabm » Wed Apr 25, 2012 6:12 pm
problem is.. t motors suddenly stall, it just vibrates without moving. i think t current/voltage isn't high enough.
plus it doesn't seem tofollow the codes as well.
athyabm
Return to Hardware
