Controlling SC08A with an Arduino
Tue Apr 24, 2012 12:51 pm
by athyabm
Hi there, I need some help controlling servo motors via the SC08A Servo Controller using an Arduino Duemilanove.
I used the manual where you simply send binary numbers that determine the servo position, speed, etc.
But however, it doesn't seem to work as expected.
Can anybody please help?
Re: Controlling SC08A with an Arduino
Wed Apr 25, 2012 7:48 am
by athyabm
thank u shahrul for t reply.
so do we have to put in a hexadecimal number as the 'byte'?
i was using decimal all this time. no wonder it wasnt working lol
Wed Apr 25, 2012 11:56 am
by shahrul
It's dos't matter with hexadecimal or decimal or binary.
You can write 0xC0 (in hex) or 192 (in dec) or 0b11000000 (in binary). All the serial out is still same.
Wed Apr 25, 2012 5:02 pm
by athyabm
Ok.
I'm connecting a small servo to open and close the robot gripper as shown
http://cytron.com.my/viewProduct.php?pc ... %20Gripperand
another servo to rotate the whole gripper through an angle of 180 degrees
http://cytron.com.my/viewProduct.php?pc ... vo%20Motorcould you pls tell me a suitable voltage to apply across the sc08a controller
here are a few video demos of t gripper
http://www.youtube.com/watch?v=m_vvW6ZqJnIhttp://www.youtube.com/watch?v=9K6puD1OqH8http://www.youtube.com/watch?v=XAOTlNAqqwQ
Wed Apr 25, 2012 5:34 pm
by shahrul
The video looks servo can run, what's the problem?
You can use voltage 5V with high amp capability, not from USB or Arduino source.
I use voltage regulator 7805 can drive 4 servo, see example here
Servo Controller.
Wed Apr 25, 2012 6:12 pm
by athyabm
problem is.. t motors suddenly stall, it just vibrates without moving. i think t current/voltage isn't high enough.
plus it doesn't seem tofollow the codes as well.
