Single channel 12V relay breakout board
Postby neverlog » Thu Apr 18, 2013 10:10 am
I just bought this relay board(BB-RELAY-12V-01 ).
It suppose will be the easiest thing ever, but it doesn't work at all!
VCC- Connect 5V
GND- Ground
GND- Ground
IN- Connect to one of the PIC pin with 5V output.
After I set the pin high(5V), the transistor become overheat, and it doesn't trigger the relay.
Please help!! Thanks
Lam
neverlog
Re: Single channel 12V relay breakout board
Postby gadgetng » Thu Apr 18, 2013 11:59 am
Are you sure there is a 5V on that pin? You can also test it directly with IN connected to 5V. If you don't hear any sound i guess you need to write in the form under the Cytron's Support tab. :lol:
gadgetng
Postby neverlog » Thu Apr 18, 2013 12:05 pm
Thanks, mate!
neverlog
Return to Hardware
