Inquiry on URS232A
Inquiry on URS232A
Postby maazri38 » Tue Dec 03, 2013 10:28 am
I had bought your URS232A last week.
I had tested the device with the correct circuit and coding that had been successfully tested before.
Unfortunately, it is not functioned.
May I know how to check whether the device is well-functioned?
As I know to check the functionality of the RS232 circuit by using loop back testing on pin 11 and 12 at MAX232.
I had tried on the device, but it is still not functioned.
maazri38
Re: Inquiry on URS232A
Postby robosang » Sat Dec 07, 2013 6:38 pm
I do not have that think, but it will be helpful if you share the picture of hardware setup and wiring.
Postby ncg223 » Fri Jan 17, 2014 6:52 pm
confused on the schematics connection of URS232A
which pins is connected between DB9 connector and MAX232 and which is the looping pins on the schematics of URS232A??
ncg223
Postby ober » Mon Jan 20, 2014 10:30 am
ncg223 WROTE:hi,
Actually we use footprint for female DB9 but designed for male DB9, so you get confused. Anyway, here is it: referring to schematic
pin 1 of DB9 which is GND is connected to GND
pin 2 of DB9 which is DTR is connected to pin 9 pf DB9 which is DSR
pin 3 of DB9 which is TX is connected to pin 14 of MAX232 (T1 out)
pin 4 of DB9 which is RX is connected to pin 13 of MAX232 (R1 In)
pin 5 of DB9 which is DCD is connected to nothing
pin 6 of DB9 which is RI is connected to nothing
pin 7 of DB9 which is CTS is connected to pin 8 of MAX232 (R2 In)
pin 8 of DB9 which is RTS is connected to pin 7 of MAX232 (T2 out)
Postby ncg223 » Mon Jan 20, 2014 5:04 pm
hi thanks for the information....
those information really help me a lot :D
but can i connect pin 2 as RX pin 3 as TX??
By the way can URS232A working with RS232 GSM/GPRS Modem??
http://www.cytron.com.my/viewProduct.ph ... RS%20Modem
here is the link to the GSM link...
ncg223
Return to Hardware
