confuse on URS232A connection
Postby ncg223 » Fri Jan 17, 2014 6:47 pm
which pins on DB9 connector is connected with the MAX232 and which pins is a loop connection
ncg223
Re: confuse on URS232A connection
Postby ncg223 » Fri Jan 17, 2014 10:18 pm
hi this is the link to the product....
http://www.cytron.com.my/usr_attachment/URS232A.pdf
ncg223
Postby ober » Mon Jan 20, 2014 10:43 am
referring to the hardware, look at the pin on the hardware label, you should connect pin 2 and 3 to perform loop back test.
Postby kathleencjustice » Sat Jun 11, 2016 1:28 pm
Ask with experts because only they can tell you the exact answer.
kathleencjustice
Return to Hardware
