LCD keypad Shield problem ?
Postby alung92 » Fri Oct 17, 2014 3:26 pm
what happen with this ? is that my code problem or the lcd shield probem ?
[img]
[/img]
#include <LiquidCrystal.h>
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
  Serial.begin( 9600 );
  lcd.begin(16, 2);
  lcd.clear();
  lcd.setCursor(0,0);
  lcd.println( "hello world!    ");
  delay(1000);
alung92
Re: LCD keypad Shield problem ?
Postby Idris » Fri Oct 17, 2014 5:41 pm
Hi alung92,
I already test your code and it is working. Could you try to adjust the LCD contrast (variable resistor)? If still problem, you can contact the Technical Support by filling up this form (link).
Postby alung92 » Fri Oct 17, 2014 6:18 pm
what about like this ? no character ? all black box . the bottom column color darker than upper column. is that normal ?
alung92
Postby Idris » Mon Oct 20, 2014 8:44 am
If you already upload the code successfully to Arduino, it should be a character displayed on the LCD.
But if the LCD still blank, probably the SHIELD-LCD is defect. Please contact the Technical Support by filling up this form (link).
Postby kathleencjustice » Sat Jun 11, 2016 1:26 pm
Take that to some experts.
kathleencjustice
Return to Hardware
