Solar Charging Lipo Battery
Postby Hayeonggeol » Fri Oct 20, 2017 5:22 pm
I had bought a 6V 3W solar panel and 7.2V 900maH lipo battery from Cytron.
I wish to design a solar charging circuit to charge this lipo battery with the 3W solar panel.
Any advice?
Hayeonggeol
Re: Solar Charging Lipo Battery
Postby sich » Thu Oct 26, 2017 11:25 am
It's not advisable to charge 7.4V 2-cell lipo battery with a 6V 3W solar panel. Solar panel ratings are stated based on the optimum condition. The output voltage is already less than 2-cell lipo battery, you have to boost it up and expect energy loss to the already very limited power converted from solar energy. Besides we should always balance-charge lipo cells too. So you will need to design or add a balancer to your circuit to protect/preserve the lipo battery. Charging 1-cell lipo is more straightforward in this case. Assuming your circuit is working perfectly, you also need to consider the time needed to fully charge your 900mAh lipo battery with a solar panel.
Postby floryss » Thu Jun 21, 2018 1:29 pm
Hi guys! I am starting a new project on solar energy. But at first i need a solar panel which can generate enough power for a air pump. But i don,t know which panel will be perfect! Can any one help me? :( :(
floryss
Return to Power
