6V/2.3Ah Lead Acid battry HELP!!! urgent
Posted: Thu Dec 16, 2010 2:03 pm
can i directly connect SLA battery 6V/2.3Ah using a normal wire to a voltage regulator (7805) and the supply 5v to PIC16,RC Micro Servo Motor and L293D motor driver ?
i have a problem in terms of power supply,where is not sufficient to rotate the servo motor if i use a normal 9V battery but the motor driver can rotate..
Help.. tq
Help.. tq
