recharge battery with DC supply?
Postby lucas07 » Wed Dec 12, 2012 5:38 pm
Can i charge 6XAA rechargeable batteries (7.2V) with DC supply (9V,800ma)?
lucas07
Re: recharge battery with DC supply?
Postby zhenning » Wed Dec 12, 2012 7:09 pm
lucas07 WROTE:
Post by lucas07 » Wed Dec 12, 2012 5:38 pm
Depending on the rating of your battery and connection. I would suggest you to get a proper charger if possible.
zhenning
Postby robosang » Wed Dec 12, 2012 10:04 pm
Agreed with zhenning..... you might get lucky, but .... mostly will spoil the battery or shorten the life.
Postby lucas07 » Thu Dec 13, 2012 1:42 pm
Thanks for the reply!
The battery is 7.2V with 700mah, don't know whether it could charge using 9V 800ma adapter or not
I'm finding a way to charge the batteries without using a market charger.
lucas07
Postby yonghui » Thu Dec 13, 2012 3:29 pm
1st do u know the full charge voltage of the battery? nominal cell voltage is 1.2V but a fully charge battery should be 1.4++v
2nd do u know how do u detect whether a battery is fully charged? there is a proper method, either by temperature or by voltage change rate.
3rd do u know the dangerous of serially charge the battery pack? u might over charge or undercharge some of the cell inside.not all cell inside the pack charge or discharge at the same rate.
if u dont mind about ur battery pack life time, then u can simple charge it with improper method. the battery might leak.
see the link below on guidline of charging nickel based battery, or NiMH battery.
http://batteryuniversity.com/learn/arti ... al_hydride
Postby lucas07 » Thu Dec 13, 2012 6:44 pm
Thanks for the reply.
Actually the 7.2V battery is the battery that used in remote control car. The batteries are sealed together when i bought it, and there are 6AA batteries in it. Sorry if my description state it unclear.
Does this make any differences with 6XAA in series?
lucas07
Postby zhenning » Thu Dec 13, 2012 6:53 pm
lucas07 WROTE:Thanks for the reply.
Ahh.. I have the same battery rating too. The charger is rated at 7.2V 250mA :)
zhenning
Return to Power
