Power bank as battery for robots?
Postby Adamzxtan » Fri Nov 01, 2013 2:26 pm
Hi, I suddenly have a crazy thought. I'm thinking about whether the power banks that we used to recharge our smartphones can be used as battery for robots or power source for any projects? I mean it's basically another battery with Li-ion, NiMH or LiPo battery inside, so why don't we use it?
Adamzxtan
Re: Power bank as battery for robots?
Postby low5545 » Fri Nov 01, 2013 11:36 pm
Sure, why not. You just need to strip out a USB cable and extract the VCC and GND wires.
low5545
Postby Adamzxtan » Sat Nov 02, 2013 3:10 pm
What if I just keep the powerbank and modify the USB head into JST-XH head or tamiya connector head? By the way, which kind of head is better suit for this kind of battery? Is there anything has to be reminded before modifying?
Adamzxtan
Postby ABSF » Sun Nov 03, 2013 6:28 am
Not sure how is the power bank is designed.
Since it is used to charge smart phones for long talk time and during travelling. I guess the voltage and current output from the power bank are regulated and controlled as handphones seldom need more than 5V DC or 500mA for charging. Your robot may need 7.6V or maybe 12V for the motors' operation. So make sure that the voltage and current output from your power bank are correct before purchasing the device.
Postby ober » Fri Nov 08, 2013 10:16 pm
Good idea, is always good to explore. Do let us know the result, share with us.
Return to Power
