problem with SLD 936 ESD Station
Soldering, Multimeter, Plier, Cutter, Screwdriver.....
Re: problem with SLD 936 ESD Station
Postby ABSF » Tue Dec 06, 2011 7:04 am
goodstudent WROTE:"I just check it with a meter"-ABSF
what thing your checked? is temperature of iron,continuity ,voltage or something else..
My iron is different from yours. It has only 4 points. 2 of them are for the iron heater element and the other 2 for the heat sensor. I think the heat sensor is just a thermo-resistor, where the resistance changes with heat. When I measured the heater element the resistance was consistant no matter how I shook the iron cable. But when I measured the sensor resistance it was sometimes open circuit and sometimes got resistance when I shook the cable. That's why I said the "sensor is intermittent".
The problem was solved after I replaced the iron.
Return to Tool and Equipment
