Code error
Code error
Postby anonymous_k87 » Wed Feb 03, 2010 2:41 pm
Do anyone know what wrong with the code?
I cant build it...I'm getting this:
Error [312] C:\Users\Kyran\Documents\C\NEW4\code_rx.c; 10.1 ";" expected
Warning [361] C:\Users\Kyran\Documents\C\NEW4\code_rx.c; 49.8 function declared implicit int
Error [984] C:\Users\Kyran\Documents\C\NEW4\code_rx.c; 94.1 type redeclared
Error [1098] C:\Users\Kyran\Documents\C\NEW4\code_rx.c; 94.1 conflicting declarations for variable "rx_rec"
I have highlighted the showed error..plz help me out..
syntax error or logic error?
//   include
#include <pic.h>
//   configuration
__CONFIG (0x3F32)
//   define
#define errorflag   RA1
#define errorflag_1   RA2
#define display_1   PORTB
#define display_2   PORTD
//   function prototype
unsigned char rx_rec(void);
//   main function
void main(void)
   //assign variable
   unsigned char num,num_1,num_2,no, temp;
   unsigned char rx_data[21],rx_act,rx_room,rx_bui,rx_ide,rx_func,rx_sum,checksum;
   unsigned int i;
   //7 segment display
   unsigned char _7seg[16]={0x7f,0x0d,0xb7,0x9f,   //0,1,2,3
                      0xcd,0xdb,0xfb,0x0f,   //4,5,6,7
                      0xff,0xdf,0xef,0xf9,   //8,9,A,B
                      0x73,0xbd,0xf3,0xe3};   //C,D,E,F
   TRISA = 0x00;         //configure PORTA as output
   TRISB = 0x00;         //configure PORTB as output
   TRISD = 0x00;         //configure PORTD as output
   //setup USART
   BRGH = 0;            //baud rate low speed option
   SPBRG= 129;            //set boud rate to 2400bps for 20Mhz crystal
   SPEN = 1;            //enable serial port
   RX9  = 0;            //8-bit reception
   CREN = 1;            //enable reception
   //initialize variable
   num = 0;
   num_1 = 0;
   num_2 = 0;
   no  = 0;
   i=0;
   rx_act = 0xff;
   while(1)                  //infinity loop
      display_2 = _7seg[num_2];   //display 8-bit hexadecimal on 7 segment
      display_1 = _7seg[num_1];
      reset:                  //reset point:
      CREN=1;                  //enable continuos receive
      if(OERR==0)               //receive data if overrun error free
         step1:
         [color=#BF0000]temp = rx_rec();   [/color]   //store return data to temporary variable
         if(temp == rx_act)
            rx_data[i]= temp;
            i++;
            if(i==15)
               goto step2;
            goto step1;
         else
            errorflag = 1;
            goto reset;
         step2:
         for(i=16; i<21; i++)
            rx_data[i]=rx_rec();
         rx_sum = rx_data[20];
         rx_room= rx_data[19];
         rx_bui = rx_data[18];
         rx_func= rx_data[17];
         rx_ide = rx_data[16];
         checksum = rx_ide+rx_func+rx_bui+rx_room;
         if(rx_sum == checksum)
            num = rx_sum;
            num_2 = num/16;
            num_1 = num%16;
         else
            errorflag_1=1;
            goto reset;
      else CREN=0;
[color=#BF0000]unsigned char rx_rec(void)[/color]         //uart subroutine
   unsigned char rx_data;
   while(RCIF==0);               //wait for data
   rx_data = RCREG;
   return rx_data;               //return data
anonymous_k87
Re: Code error
Postby yonghui » Fri Feb 05, 2010 12:09 pm
pls add a semicolon behind ur __CONFIG(0x3F32)
which will become __CONFIG(0x3F32);
i tested the working code to be like this :
// include
#include <pic.h>
// configuration
__CONFIG (0x3F32);
// define
//#define display_2 PORTD
// main function
void main(void)
   //assign variable
   unsigned int i;
   //7 segment display
   //TRISD = 0x00; //configure PORTD as output
   //setup USART
   num = 0;
   num_1 = 0;
   num_2 = 0;
   no = 0;
   i=0;
   rx_act = 0xff;
      //   display_2 = _7seg[num_2]; //display 8-bit hexadecimal on 7 segment
            step1:
            temp = rx_rec(); //store return data to temporary variable
            if(temp == rx_act)
               rx_data[i]= temp;
               i++;
               if(i==15)
               goto step2;
               goto step1;
            else
               errorflag = 1;
               goto reset;
            step2:
               num = rx_sum;
               num_2 = num/16;
               num_1 = num%16;
               //display_2 = _7seg[num_2];
            else
            errorflag_1=1;
            goto reset;
         else CREN=0;
unsigned char rx_rec(void) //uart subroutine
rx_data = RCREG;
Re: Code error
Postby anonymous_k87 » Sun Feb 07, 2010 12:59 pm
Thanks dude.....I cant believe I miss that...
anonymous_k87
