ober WROTE:1. As long as there is analog input to read the Gyro, you can integrate it. You need to consider the power for Gyro too, normally is not 5V, is 3.3V.
3.3V? Hmm... which means I need to put a pot to varies the voltage input, am i right?
ober WROTE:2. Need to do modification on PR18
I'm still thinking about the possible modifications.
ober WROTE:3. What do you mean by directly and normal IR sensor? Do you mean want to interface directly? Yes, you can do it, just take care of the voltage for Gyro. Of course, program modification is necessary, and that is the hard part.
4. Yes, it will be hard.
Yes. Directly interfaced. Do we have any example on gyro program that i can refer to? I'm still learning how to integrate the fuzzy into the PR18 alone without the gyro. anyway, tq ober for the quick response.
