PR11 Fan Speed
PR11 Fan Speed
Postby Juf » Mon Mar 22, 2010 1:18 am
Hey,
So I bought the PR11 and everything is working fine. I was wondering if the Fans included in the kit are able to be speed controlled? If so could you give me some example code?
Juf
Re: PR11 Fan Speed
Postby ober » Mon Mar 22, 2010 9:44 am
Good to hear that it is working fine.
As for the speed control, do check the schematic, if the fan control is connected to CCP pin (RC1 and RC2), you can have PWM output to control it. If it is connected to other pin, speed control will be difficult to achieve.
Re: PR11 Fan Speed
Postby waiweng83 » Tue Mar 23, 2010 1:57 pm
Correction to Ober's reply. The speed of the fan in PR11 CANNOT be controlled. This type of fan is using brushless motor with onboard controller, there is no way to change the speed for this type of fan.
waiweng83
Re: PR11 Fan Speed
Postby black_smtk » Wed Oct 03, 2012 6:48 pm
waiweng83 WROTE:Correction to Ober's reply. The speed of the fan in PR11 CANNOT be controlled. This type of fan is using brushless motor with onboard controller, there is no way to change the speed for this type of fan.
is is true? so can PWM be used to control the fan? if canot, what type of motor needed?
black_smtk
