PR15
PR15
Postby soo » Mon Apr 12, 2010 2:18 pm
I am facing problem to display the JHD162A LCD.....
the LCD only shows full boxes in the second line and the first line is empty. the contrast part i already adjust to a suitable range......
what is the possible problem ...??? for this PR15 i didn't fix the humidity sensor.....i just want try out the gas sensor......
soo
Re: PR15
Postby ober » Mon Apr 12, 2010 4:32 pm
have you load the sample program into PIC? Can you also check the connection from LCD to PIC pin according to schematic?
Re: PR15
Postby soo » Tue Apr 13, 2010 11:07 am
ya i had load d sample program into the pic by using MPLAB through PICCLITE....i am now using the breadboard to fix the circuit according to the schematic.....but stil facing d same problem....
soo
Re: PR15
Postby ober » Tue Apr 13, 2010 11:27 am
:roll: MPLAB + PICC Lite is not to upload the code into PIC, these 2 software are IDE and Compiler only. You will need to have PIC Programmer to download the hex code into PIC.
Re: PR15
Postby soo » Tue Apr 13, 2010 12:02 pm
sorry....ya after i compile the sample in hex.....i use the PIC programmer transfer it into the PIC ....
is there any different if i use PIC16F873A or PIC16F876A...???
soo
Re: PR15
Postby ober » Wed Apr 14, 2010 8:30 am
If you have black dot on LCD, mostly the LCD is not initiated correctly.
1. It might be the PIC is not running at all, Crystal speed and configuration bit is crucial in this case.
2. Connection from PIC pin to LCD will cause this problem too. Check the connection of each and every pin of LCD to PIC, make sure it does not disconnect or shorted.
Re: PR15
Postby soo » Thu Apr 15, 2010 8:08 am
Now the sensor circuit can show one or two time d output.... but when i click the reset button then mostly show d black dot......
how can i check d PIC whether is not running ??? crystal i used 20Mhz as mention....
soo
Re: PR15
Postby ober » Thu Apr 15, 2010 8:55 am
soo WROTE:Now the sensor circuit can show one or two time d output.... but when i click the reset button then mostly show d black dot......
Can you explain clearly what do you mean by the sensor circuit can show one of two time? Showing on LCD or ?
You are using the sample source code or?
If the LCD have output, then the program is running on PIC and crystal is working. Maybe just modify the program to have some delay before initiate the LCD, because some LCD need longer time to start up.
Re: PR15
Postby soo » Thu Apr 15, 2010 12:43 pm
the LCD screen can display the string " Gas sensor" and the output in ADC form....but most of the time showing d black dot even i click on the reset button......
ya....i m using d sample code...
ok i will try out to put delay before initiate the lcd....
if the gas sensor TGS2600 is spoiled will the lcd display any output ??
soo
Re: PR15
Postby ober » Thu Apr 15, 2010 5:09 pm
It should not affect the LCD. Anyway you can always put a while loop after 1st message inorder to check the functionality of LCD.
