nagufever WROTE:May i know the Temperature Control system can be connect to a curtain and direct it to draw and close curtain system when it reaches two temperature limit(too hot and too cold)?Can explain how to work out?
nagufever WROTE:May i know which sample code are you refering to?Does PIC16F876A in the temperature controller set can be added the motor circuitary and Bluetooth (SKKKCA-21) Remote Control?Does it have enough pins to support the circuitary i mentioned above?
