is it i need to add an interrupt if i want to for both, auto and manual mode temperature control using fan?
originally, the pr 11 act as auto mode to on /off fan....and if i want to add keypad....means for manual mode to on or off the fan?
where i should add an interrupt in the programming....and what i should put the keypad?as input or output?....the original pr11, the input is temperature sensor.
redips_id WROTE:Anyone: How I want to edit the word "Quote"?
sich WROTE:Hi redips_id,redips_id WROTE:Anyone: How I want to edit the word "Quote"?
Usually i press Post Reply first and select the phrase which i want to quote from the Topic Review and press the Quote button available at the particular post. That'll result in the one as above - with the name of the one who posted the phrase.
The command is actually like this. Just change the { and } to [ and ]. I think you can recognize the logic behind it
{quote="redips_id"}Anyone: How I want to edit the word "Quote"?{/quote}
