pr 11,
pr 11,
Postby fatimah » Wed Sep 01, 2010 8:28 am
how to make a fix temperature intead using temperature sensor, because easy for me as calibration
fatimah
Re: pr 11,
Postby ober » Wed Sep 01, 2010 5:56 pm
hi, what do you like to ask actually? You want to have a fix temperature for you to calibrate the sensor on PR11 or?
Try to calibrate in aircon room where you know the room temperature, normally is 25 degree Celsius. On the PR11 and let the sensor detect the room temperature and look at the reading on LCD. You can adjust the variable resistor and also the software to do the calibration.
Re: pr 11,
Postby sich » Wed Sep 01, 2010 6:16 pm
Please explain in details...
Re: pr 11,
Postby yonghui » Thu Sep 02, 2010 9:46 am
fix a temperature for calibration? get a thermometer measure the temperature of the place then set ur temperature sensor reading as the temperature of thermometer reading.
Re: pr 11,
Postby redips_id » Fri Sep 03, 2010 1:28 am
Maybe she want to say this:
Create a system that can control temperature heater at the fix level (fix value) without using the temperature sensor. So if there is no use of temperature sensor, she will feel more easier to understand and handle the project (calibrate). haha. Just MAYBE. Sorry if I do a mistake.
redips_id
Re: pr 11,
Postby fatimah » Fri Sep 17, 2010 2:41 pm
thanks for everyone...i just got the idea...just like yonghui said
fatimah
