Hi, I have installed all components on the board and checked all components are installed correctly according the manual for PR23. Then, I follow the instruction from the UIC00B manual to load the sample program to the PR23 robot and it show successful. When I turn on the robot the LED is on, the beep sound can be heard and the IR sensor is function ok but the LCD was blank at all.
Pls. refer to details below:
- Checked PIC (VCC 5v) – ok
- Checked 5V output from 7805 - ok
- Checked gnd pad on LCD to LM7805 body connectivity – ok.
- Checked LCD Vcc pin had 5v supply.
- Checked Pin RB5 no 5V voltage.
- Microcontroller (can write and read hex but not functioning).
- Press the reset button beep sound can heard.
- Press the SW1 and SW2 one time accordingly ,the robot move straight forward only.
Pls. advise the solution thanks!
