PR15
PR15
Postby azry88_aries » Tue Oct 05, 2010 1:23 am
Hye, can anyone help me...
Is it possible to changed the TGS2600 to TGS2442?
Coz i need to measure carbon monoxide(CO) up to 200ppm..
azry88_aries
Re: PR15
Postby hyng » Tue Oct 05, 2010 9:45 am
U got TGS2242? ya, this sensor should be no problem to replace the TGS2600. :)
Re: PR15
Postby robosang » Tue Oct 05, 2010 9:50 am
azry88_aries WROTE:Hye, can anyone help me...
:? How should I answer?
1. You need to check the pins of both TGS2600 and TGS2442, whether there are pin to pin compatible if you are using the DIY PCB board from Cytron as the pin assignment on PCB is fixed. This simply means that if pin 1 of TGS2600 is 5V, pin 2 is GND (just as example), TGS2442 must have the same pin assignment. And can it fit physically into the board?
2. Also the operating voltage and the output? How is the TGS2600 send information to microcontroller? Through UART? Analog voltage? SPI? I2C? or as simple as digital output?
3. If all these are the same, you should be able to replace it and of course you need to re-program the code in order to obtain carbon monoxide value instead of the original information given from TGS2600, what ever that sensor is. :lol:
Return to DIY Project Set
