help ;why my program not running
Postby captenusop » Wed Oct 13, 2010 4:28 pm
#include<pic.h>
//#include"16f877a.h"
__CONFIG(0x3F32);
void blinked1(void);
void blinked2(void);
void init_io(void);
void delay(unsigned int DlyCnt);
unsigned int MyCnt,i;
MyCnt=DlyCnt;
while(MyCnt){
i=20000; //ubah nilai i dari 1-65535
while (i) i--;
MyCnt--;
void init_io(void)
TRISB=0b00000000;
PORTB=0b00000000;
TRISD=0b11111111;
PORTD=0b00000000;
/*main program*/
void main (void)
unsigned char Cnt;
init_io();
Cnt=0;
while(1){
if (Cnt<=5){blinked1();Cnt++;} // subroutine blinked1 akan jalan sebanyak 5 kali
if (6<=Cnt<=11) {blinked2();Cnt++;} //subroutine blinked2 akan jalan sebanyak 5 kali
if (Cnt==12) {PORTB=0b00000000;}//led akan stop
//***********Subrautine*****
void blinked1(void)
PORTB=0b11110000;
delay(5);
PORTB=0b00001111;
delay(2);
void blinked2(void)
PORTB=0b00000000;
delay(1);
PORTB=0b11111111;
delay(1);
captenusop
Re: help ;why my program not running
Postby kl84 » Wed Oct 13, 2010 11:58 pm
Because of this:
while (i) i--;
The argument in while() must be 1 or 0, not other values. An appropriate way to do what you wish to carry out here is:
while(i>0) i--;
kl84
Postby captenusop » Thu Oct 14, 2010 2:18 pm
In my project i must create counter.
the subroutine delay, blinked1 and blinked2 are working.
The problem is when
if (Cnt=12) PORTB=0b00000000;//
all the led suppose to stop blinking here but there still blinking.
captenusop
Postby ober » Thu Oct 14, 2010 5:26 pm
kl84 WROTE:Because of this:
while (i) i--;
Actually C allow this. As long as the value inside ( ) is not zero, it will return true. Therefore,
while(i) is the same as while (i != 0).
captenusop WROTE:In my project i must create counter.
The problem is when
What is the blinking pattern after 1st loop? pattern 1 or pattern 2? Or it loop both pattern?
Postby kl84 » Thu Oct 14, 2010 5:31 pm
Ooo...thanks for the info!
what about this:
if (6<=Cnt<=11)
Is it allowed?
kl84
Postby captenusop » Fri Oct 15, 2010 9:16 am
if (Cnt==12) PORTB=0b00000000;// the program will loop patern 2
if (Cnt<=12) PORTB=0b00000000;// the program will loop patern 1 and 2
captenusop
Postby shahrul » Fri Oct 15, 2010 2:50 pm
I have 1 example LED Blinking here.
Postby captenusop » Fri Oct 15, 2010 4:48 pm
led is blinking in 2 pattern. but my counter(variable) is not working.
captenusop
Postby shahrul » Fri Oct 15, 2010 5:22 pm
captenusop WROTE:led is blinking in 2 pattern. but my counter(variable) is not working.
If all your function is working, maybe you can try this way.
else if (Cnt<=11) {blinked2();Cnt++;} //subroutine blinked2 akan jalan sebanyak 5 kali
else if (Cnt==12) {PORTB=0b00000000;}//led akan stop
Postby captenusop » Sat Oct 16, 2010 8:16 am
:lol: thanks,, its working
captenusop
