transfering data to UC00A
Postby kane » Fri Oct 22, 2010 11:09 pm
hi..i'm currently having problem with transferring data to uc00A using visual basic programming...anyone hv any clue on how to do it?
kane
Re: transfering data to UC00A
Postby sich » Fri Oct 22, 2010 11:59 pm
UC00A will create a virtual com port in your computer. So what u need to do is to open that specific com port in order to transmit/receive data from it. To check the correct com port, just go to Control Panel > System > Device Manager. Look into the Ports (COM & LPT). You'll find a new com port listed inside there.
Postby kane » Sat Oct 23, 2010 1:37 pm
ohh..ok..i will try it..thx ya.. :)
kane
Postby kane » Sat Oct 23, 2010 6:48 pm
erm..do u know how to access the com port in visual basic? it is a serial or parallel port? i am new to visual basic..
kane
Postby sich » Sun Oct 24, 2010 3:03 am
It's serial port.
You will need to establish the port in your vb program.
Dim WithEvents port As SerialPort = New System.IO.Ports.SerialPort("[color=#FF0000]COM1[/color]", 9600, Parity.None, 8, StopBits.One)
You may use the port like this...
port.Open()
port.Write(txtSendText.Text & "!%")
port.Close()
MSDN has the full details about SerialPort Class. There're a lot of example available in the internet. Cytron also provides some .NET sample source code here:
1. SC16A
2. SD02B
Postby kane » Sun Oct 24, 2010 4:24 pm
thx ya...err the program that u write :
txtSendText.Text, is it the text that i wanted to send to the port?
and what is "!%" ?
kane
Postby sich » Sun Oct 24, 2010 6:16 pm
It's just an example...
Yes. That function will send string through serial port. "!%" is another string placed behind "txtSendText.Text". It can be any characters though.
There're also WriteChar & WriteByte functions if not mistaken.
U may refer to msdn for the argument to be put inside the function or just trial-n-error.
