RP11 programing code question
Postby lihker » Fri Nov 05, 2010 4:20 am
can somebody explain to me this code tq
send_char(0b11011111);
come from
//sensor B
ADCON0=CHANNEL1; //CHANNEL0=0b10000001
lcd_goto(28);
read_adc();
temp=read_temp();
dis_num(temp/10);
send_char('.');
dis_num(temp%10);
send_char('C');
send_char(' ');
send_char(' ');
tempB=temp;
lihker
Re: RP11 programing code question
Postby yonghui » Fri Nov 05, 2010 9:33 am
send_char(0b11011111);     //sending 1byte data to somewhere
//come from
//sensor B
                                 //changing the channel of the ADC to read value
lcd_goto(28);               // moving the position of LCD to corresponding position
read_adc();                  // read ADC function is called to read the selected channel
temp=read_temp();        // read temperature function is called to process the data to obtain the temperature value from raw ADC data
dis_num(temp/10);         //display most significant digit of the 2 digit number
send_char('.');               // display a ' .'
dis_num(temp%10);        //display least significant digit of the 2 digit number
send_char(0b11011111); // sending 1byte data
send_char('C');              //sending  a 'C' ascii
send_char(' ');              //sending space
send_char(' ');
tempB=temp;                 // backup temp value?
Postby lihker » Fri Nov 05, 2010 12:25 pm
tq yh
yonghui WROTE:hi,
//come from
//sensor B
send_char(' ');
lihker
