garfield WROTE:why will password error? I follow all the step without change anything in the c.file or hex file, after i write in and test it, it show error.
ober WROTE:garfield WROTE:why will password error? I follow all the step without change anything in the c.file or hex file, after i write in and test it, it show error.
Can you share a picture of your circuit? The setup?
hyng WROTE:LCD shows the correct words?
Which steps has failed? Please compare with the video below:
http://www.youtube.com/watch?v=5jDoWjrTd8U
Does the LCD shows " * " when u press the key pad?
ABSF WROTE:Hi, have you check the 8 soldering joints on the keypad with an ohmmeter? May be two of the points are shorted.
