PR 9B : Password Door Security V2010
Re: PR 9B : Password Door Security V2010
Postby ABSF » Fri Dec 31, 2010 10:39 am
Do you know how to modify the program code? Try to modidy it so that the number you pressed is shown on the LCD instead of just the "*". So you can tell whether the number that you entered is correct:
void scancolumn2(void)
   if(RA0==0)                     //if key '4' is being pressed
      while(RA0==0)continue;         //waiting the key to be released
      if(password_count==0)lcd_clr();   //Clear the LCD if the key is the 1st password
      lcd_goto(password_count);      //The cursor of LCD points to the column equivalent to the value of password_count variable
      send_char('*');               //Display the symbol '*' at LCD
      keyin_char[password_count]='4';   //Stall the '4' value at the keyin_char array
      password_count+=1;            //increase the Password_count variable's value by 1 and the result stall back to the variable
   else if(RA1==0)                     //if key '5' is being pressed
      while(RA1==0)continue;         //waiting the key to be released
      keyin_char[password_count]='5';   //Stall the '5' value at the keyin_char array
Put the code :send_char('*');
after the code : keyin_char[password_count]='4';
as code : send_char('4');
Modify the rest of the code from ('*') to the corresponding numbers.
In this way when you keyin the password, you can see what numbers you've just entered. Then you can tell if your keypad is working properly. If you get '123456' and the message is still "FAIL", well, either the password in the program has been changed or your program is corrupted.
