// include
#include <pic.h>
// Configuration
__CONFIG ( 0x3F32 ); //configuration for the microcontroller
// Define
#define rs RC3 //RS pin of the LCD display
#define rw RC2 //R/W pin of the LCD display
#define e RC4 //E pin of the LCD display
#define b_light RC1 //backlight of the LCD display (1 to on backlight)
#define buzzer RC0 //buzzer (1 to on buzzer)a
#define button1 RA0 //button (active low)
#define button2 RA1 //button (active low)
#define lcd_data PORTB //LCD 8-bit data PORT
#define led1 RA2 //led 1 (active high)
#define led2 RA3 //led 2 (active high)
// Function prototype (every function must have a function prototype)
void lcd_clr(void);
unsigned char uart_rec(void);
void beep(void);
// Main function (main fucntion of the program)
void main(void)
//assign variable
unsigned char i,temp,database;
unsigned char data[15]; //14 bytes of data received from RFID Reader.
//The data include start of text, RFID ID,
//carriage return, new line, and end of text
unsigned char id_1[10]={"0010810115"}; //define the Tag ID here
unsigned char id_2[10]={"0000797447"}; //change this ID to the tag ID that user want to read
[color=#FF0000] unsigned char id_3[10]={"0000123456"};[/color] //change this ID to the tag ID that user want to read
unsigned char user_1[10]={"Ikhwan"}; //define the Tag user here
unsigned char user_2[10]={"Othman"}; //change this user name to the tag ID owner name
[color=#FF0000]unsigned char user_3[10]={"Nurdiana"};[/color]
//set I/O input output
TRISB = 0b00000000; //configure PORTB I/O direction
TRISC = 0b10000000; //configure PORTC I/O direction
TRISA = 0b11110011; //configure PORTA I/O direction
//setup USART
SPBRG = 0x81; //set baud rate to 9600 for 20Mhz
BRGH = 1; //baud rate high speed option
TXEN = 1; //enable transmission
CREN = 1; //enable reception
SPEN = 1; //enable serial port
//setup ADC
ADCON1 = 0b00000110; //set ADx pin digital I/O
//configure lcd
send_config(0b00000001); //clear display at lcd
send_config(0b00000010); //lcd return to home
send_config(0b00001100); //display on, cursor off and cursor blink off
send_config(0b00111000); //function set
//set initial condition
buzzer=0; //off buzzer
b_light=1; //on backlight
led1=0; //off led 1
led2=0; //off led 2
lcd_clr(); //clear lcd
lcd_goto(0); //set the lcd cursor to location 0
send_string("RFID Student"); //display welcome note
lcd_goto(20); //set the lcd cursor to location 20
send_string("Attendance"); //display welcome note
beep(); //initial beep
delay(20000); //delay for display the welcome note
//infinity loop
CREN = 1; //enable reception from UART
lcd_goto(0); //set lcd cursor to location 0
send_string("Place your ID"); //display note
lcd_goto(20); //set lcd cursor to location 20
send_string("on the reader."); //display note
for(i=0;i<14;i+=1)data[i]=uart_rec(); //wait for 14 character data receive from RFID reader
//The data receive are start of text, RFID ID,
led1=1; //on led to indicate system is busy
send_string("Processing......"); //display "Processing...."
delay(40000); //delay
database=0; //clear the value of database and start scanning
//comparing with the 1st id
temp=0; //comparing the received data with the saved id.
//only byte 2-11 which is RFID ID data, will be used to compare between
//receive data and saved id.
for(i=1;i<11;i+=1) //comparing digit by digit
if((data[i])!=(id_1[i-1]))temp=1; //if the id is different from the id define above,
} //then set temp=1;
if(temp==0) database=1; //if temp=0, mean the id match, set the database=1
//comparing with the 2nd id
if((data[i])!=(id_2[i-1]))temp=1; //if the id is different from the id define above,
if(temp==0) database=2; //if temp=0, mean the id match, set the database=1
[color=#FF0000]//comparing with the 3rd id
if((data[i])!=(id_3[i-1]))temp=1; //if the id is different from the id define above,
if(temp==0) database=3; //if temp=0, mean the id match, set the database=1 [/color]
CREN = 0; //disable reception from UART
switch(database)
case 1: //id 1 match
led2=1; //on led 2
send_string("ID:"); //display "ID: "
for(i=0;i<10;i+=1)send_char(id_1[i]); //display tag ID
send_string("user:"); //display "user: "
for(i=0;i<10;i+=1)send_char(user_1[i]); //display user name
beep(); //beep once
break;
case 2: //id_2 match
led2=1; //on led 2
send_string("ID: "); //display "ID: "
for(i=0;i<10;i+=1)send_char(id_2[i]); //display tag ID
for(i=0;i<10;i+=1)send_char(user_2[i]); //display user name
beep(); //beep once
break;
[color=#FF0000]case 3: //id_2 match
led2=1; //on led 2
for(i=0;i<10;i+=1)send_char(id_3[i]); //display tag ID
for(i=0;i<10;i+=1)send_char(user_3[i]); //display user name
beep(); //beep once[/color]
break;
default: //id doesnt match
for(i=1;i<11;i+=1)send_char(data[i]); //display tag ID
send_string("user not found"); //display "user not found"
beep(); //beep twice
beep();
break;
delay(300000); //delay
led1=0; //off led after the process complete
led2=0;
// Functions
void delay(unsigned long data) //delay function, the delay time
{ //depend on the given value
for( ;data>0;data-=1);
void send_config(unsigned char data) //send lcd configuration
rw=0; //set lcd to write mode
rs=0; //set lcd to configuration mode
lcd_data=data; //lcd data port = data
e=1; //pulse e to confirm the data
delay(50);
e=0;
delay(50);
void send_char(unsigned char data) //send lcd character
rs=1; //set lcd to display mode
delay(10);
e=0;
delay(10);
void lcd_goto(unsigned char data) //set the location of the lcd cursor
{ //if the given value is (0-15) the
if(data<16) //cursor will be at the upper line
{ //if the given value is (20-35) the
send_config(0x80+data); //cursor will be at the lower line
} //location of the lcd cursor(2X16):
else // -----------------------------------------------------
{ // | |00|01|02|03|04|05|06|07|08|09|10|11|12|13|14|15| |
data=data-20; // | |20|21|22|23|24|25|26|27|28|29|30|31|32|33|34|35| |
send_config(0xc0+data); // -----------------------------------------------------
void lcd_clr(void) //clear the lcd
send_config(0x01);
delay(600);
void send_string(const char *s) //send a string to display in the lcd
unsigned char i=0;
unsigned char uart_rec(void) //receive uart value
unsigned char rec_data;
while(RCIF==0); //wait for data
rec_data = RCREG;
return rec_data; //return the data received
void beep(void) //short beep function
buzzer=1; //on buzzer
delay(10000); //short delay
bahirah87 WROTE:im using MPLAB. i have tried several time to add more user id in my programming and add some more character to id name but the programming cannot been compile.. what should i do?
bahirah87 WROTE:it can be compile but i have done the simulation using proteus 7.1 ... and with original program the LCD show the name.. after i add one more name and id the LCD show "user not found"
