PR26 (Build Failed)
PR26 (Build Failed)
Postby WSTOK » Fri Mar 18, 2011 12:44 am
Hi ,
I just bought the DIY kit PR26 and i follow the instrution to added the necessary file to the MPLAB IDE. When i build the project ,the message box showing BUILD FAILED. Pls. advise the solution. Thanks !
Debug build of project `C:\Users\user\Desktop\robot\joystick.mcp' failed.
Preprocessor symbol `__DEBUG' is defined.
Fri Mar 18 00:32:04 2011
BUILD FAILED
WSTOK
Re: PR26 (Build Failed)
Postby ober » Fri Mar 18, 2011 8:30 am
Hi, can you print screen the project window and output window of MPLAB IDE and paste here? It will be much more useful.
Postby WSTOK » Sun Mar 20, 2011 2:27 am
Hi ober,
The build failed already solve. But i can't use the pr26 as mouse function in my notebook. Is it need to change the program configuration?Thank you.
WSTOK
Postby robosang » Sun Mar 20, 2011 8:37 am
WSTOK WROTE:Hi ober,
Curious to know what is the root cause for the previous failure. 8-)
Postby WSTOK » Sun Mar 20, 2011 11:54 pm
Previous failure was due to C18 Compiler didn't link with MPLAB IDE, so i went to cytron taman U and show them this problem. They very patience and very helpful to found out my problem and help me manually link the C18 compiler to MPLAB IDE. I very appreciate their help. Pls. refer to the attached picture for select language Toolsuite ,before that the Microchip C18 Toolsuite did not appear in the Toolsuite list.
WSTOK
Postby WSTOK » Mon Mar 21, 2011 3:37 pm
I hope someone can sharing the idea how to change this PR26 to mouse function. Thanks!
WSTOK
Postby ober » Tue Mar 22, 2011 9:51 pm
WSTOK WROTE:I hope someone can sharing the idea how to change this PR26 to mouse function. Thanks!
We have already share the method in ROBOT.Head to Toe magazine, cannot remember which volume, you can try checking volume 4 or 5. The sample source code is on the website too: http://robothead2toe.com.my/
Postby WSTOK » Wed Mar 23, 2011 11:19 pm
Thank you :P
WSTOK
Postby WSTOK » Tue Mar 29, 2011 10:05 pm
Hi Ober,
i had try the mouse source code and i facing some error when i build all. Kindly advice.
output
MPLAB IDE project files
WSTOK
Postby yonghui » Tue Mar 29, 2011 10:13 pm
from the screen shots.
the file missing is the problem u will need to locate the missing file.
copy the necessary file into the project directory.
i think u can find those file from the source given in the magazine website
or else u will need to find from the microchip's folder.
