PR12 Real time clock
Postby wci » Sun Apr 03, 2011 11:39 pm
Hi everyone,
i have built up the real time clock according to the schematic and component list in PR12 project set. I have also use the sample source code from PR12 project set as well.. however, the clock didn't run properly after i set the time.. it returned to 00:00:00 when i pressed the mode button after setting the day.. both software and hardware simulation are showing the same problem. i wonder why is it like that? Anyone can help? Appreciate it very much!
wci
Re: PR12 Real time clock
Postby joliza » Mon Apr 04, 2011 12:10 pm
wci WROTE:Hi everyone,
Can you capture photos of the hardware and upload here. Might get some problem there.
joliza
Postby wci » Wed Apr 06, 2011 9:27 am
I am using breadboard testing and it is messy. I have check many times on the connection. Basically i connected the circuit according to the schematic available in PR12 (http://www.cytron.com.my/usr_attachment ... ematic.pdf). Just that i am using PIC16F877A and i change the port for switches and rs and e pin for LCD display for convenience during hardware connection. And i didn't connect UIC00A Programmer Connector.. Hope to see your replies soon.. Thanks!
wci
Postby yonghui » Wed Apr 06, 2011 5:31 pm
to little info from u. hardly for me to imagine wat happen to ur circuit.
at least some pictures. or more descriptive info on the circuit and problems. have u done any debug on it?
Postby wci » Wed Apr 06, 2011 8:17 pm
Ya.. it showed "Build successful!". I have 3 source codes: PR12.c, i2c.c and i2c_rtc.c. My header files are pic.h, i2c.h and i2c_rtc.h. My circuit schematic is shown as follows: http://postimage.org/image/5ylw7chw/
Please help me check and hope to see ur replies soon.. Thanks!
wci
Postby Brian Griffin » Wed Apr 06, 2011 10:40 pm
You will need pull-ups for the SDA and SCL line. Put at least a 4.7k resistor which is connected to the +5V and each of the I2C connections.
Please bear with me as my drawing skills isn't perfect and a bit too rushed.
Btw - due to the stray capacitance and loading effect on breadboards, the DS1307 and the crystal could not accurately keep the time after a few hours or days. You need to solder the DS1307, the crystal, the battery holder (and put battery inside after solder) all onto a Printed Circuit Board for a better timekeeping.
Postby wci » Thu Apr 07, 2011 12:27 am
Thanks.. I have done it, but the problem is still the same.. is it related to programming problem?
wci
Postby ober » Thu Apr 07, 2011 10:23 pm
Postby IsaacChuah90 » Mon Jul 18, 2011 11:50 am
Hi guys.I'm using pic16f877a instead of using pic16f876a,and I connect all the components including real time clock and LCD according to the schematic shown in pr12,the LCD can't show the time,it just show nothing.and I programmed the sample code inside the pic16f877a which include c file and hex file from pr12.it can't work..seeking for help.thanks!!!
IsaacChuah90
Postby yonghui » Tue Jul 19, 2011 11:05 pm
did u recompile the project for PIC16F877a with the correct device selected in MPLAB to get a new HEX for ur PIC?
the HEX for 876a cant fit 877a
