PR8-B (provided with modified source code)
Postby kwlew » Tue Apr 05, 2011 12:17 pm
Hi, i would like to modify the source code of the PR8-B diy project.
Currently the source code i download from cytron is only match the RFID tag and display the name and id.
I have an idea to modify the source code become an attendance system.
for an example:
-there are two RFID card, one RFID card is tagged and the data is store while another one is no tag.
-there are two button in these diy set and i would like to make one of the button, when we press it and it will show the data of
the card that we already tagged. While the other button when we press, it will show the card that are not tag.
Any idea how do that?
kwlew
Re: PR8-B (how to modified source code)
Postby ober » Thu Apr 07, 2011 9:54 pm
Hi, you will need to take the move first before we can help you. Try to modify the program part by part, and load to the hardware, look at the result, share with us. From there, the other can help by giving you opinion. It is not possible for someone to provide you total solution here.
Postby kwlew » Sat Apr 09, 2011 7:01 pm
Hi, i modified the code and it works.
But when i press the button it not 'stable'.....for an example, there are two id tagged and when i press once it will show the data for the first id. Then when press second time it suppose will show second data of the second id, but i need to press many time only the second data will appear in the lcd.
How to fix the problem?
Here is the code that i modified.
unsigned char uart_rec(void)          //receive uart value
   unsigned char rec_data;
   while(RCIF==0)                                  //wait for data
      if (button1==0&&present[0]==0)
         lcd_clr();
         lcd_goto(0);                            //set lcd cursor to location 0
         send_string("Not Present!");                //display "Not Present "
         lcd_goto(20);                            //set lcd cursor to location 20
         for(i=0;i<10;i+=1)send_char(user_1[i]);       //display user name
         delay(100);
      if (button1==0&&present[1]==0)
         lcd_clr();
         for(i=0;i<10;i+=1)send_char(user_2[i]);       //display user name
         delay(100);
      if (button1==0&&present[2]==0)
         lcd_clr();
         for(i=0;i<10;i+=1)send_char(user_3[i]);       //display user name
         delay(100);
      if (button1==0&&present[0]==1&&present[1]==1&&present[2]==1)
         lcd_clr();
         send_string("All Present!");                //display "Alll Present "
         delay(100);
      if (button2==0&&present[0]==1)
         lcd_clr();
         send_string("ID: ");                      //display "ID: "
         for(i=0;i<10;i+=1)send_char(id_1[i]);          //display tag ID
         send_string("user: ");                      //display "user: "
         entry+=1;
         delay(100);
      if (button2==0&&present[1]==1)
         lcd_clr();
         for(i=0;i<10;i+=1)send_char(id_2[i]);          //display tag ID
         entry+=1;
         delay(100);
      if (button2==0&&present[2]==1)
         lcd_clr();
         for(i=0;i<10;i+=1)send_char(id_3[i]);          //display tag ID
         entry+=1;
         delay(100);
   rec_data = RCREG;
   return rec_data; //return the data received
kwlew
Re: PR8-B (provided with modified source code)
Postby shiyan » Sun Apr 10, 2011 4:16 pm
well, I din refer to the DIY project that you mentioned, but your source code is very weird. Why is the program to store ID and pressing is in the uart_rec function? Can you explain in detail what is the output? I doubt you can get a correct output using this code.
shiyan
Postby kwlew » Tue Apr 12, 2011 8:19 am
the project is when we tagged the rfid card, it will store the id and name in the pic. after that we can press the button to check the name and id that stored in the pic, the name and id will show in the lcd. so which part will you suggest i should put the pressing program?
kwlew
Postby sich » Thu May 05, 2011 2:28 pm
Seems like you put ur scan buttons commands in the uart communication subroutine. I don't know how's the rest of your code, i guess you should take it out...and put it somewhere else, eg: main.
