PR9-B Passwood Door Security
Postby Alsayed7 » Tue Sep 20, 2011 7:00 pm
Hi , I have some questions and I need answers
1. How long it takes from the confirmation of the purchased order of the project until it reaches me? I am living in middle east in Bahrain.
2. Can I change the defult password (( 123456))? , if yes please tell me how.
3. Do I need to buy something that not included in project set?
I need answers ASAP.
thanks
Alsayed7
Re: PR9-B Passwood Door Security
Postby ober » Wed Sep 21, 2011 10:05 am
Alsayed7 wrote:1. How long it takes from the confirmation of the purchased order of the project until it reaches me? I am living in middle east in Bahrain.
Hi, most of the answers can be obtained here, theFAQ page
2. Yes, you can change your password. Login your account using existing password, goto "Member Account", key in your new password twice.
3. Yes, for those optional item (example power adapter) you will need to buy separately as some might already have it.
Postby Alsayed7 » Wed Sep 21, 2011 7:04 pm
thanx ,,, but I mean the passwoed of my project (( as defult 123456)) how to change it
Alsayed7
Postby ober » Thu Sep 22, 2011 12:34 pm
OK, misunderstood.
You will need to change the sample source code of PR9-B.
Postby Alsayed7 » Mon Sep 26, 2011 3:31 am
Can u tell me which part of source code exactly ?
Alsayed7
Postby ober » Mon Sep 26, 2011 5:21 pm
Alsayed7 wrote:Can u tell me which part of source code exactly ?
You need to study the sample code in order to understand how the whole system works.
Look for "123456" in the code.
Code: Select all
//   global variable
unsigned char password_count=0;
unsigned char keyin_char[6];            // Declare an array to stall the 6-digit key in password
unsigned char stalled_char[6]="123456";      // Declare an array to stall the 6-digit desired password
change the value of "123456" to the desire password you need, remember it must be 6 characters.
Postby shiyan » Tue Sep 27, 2011 9:50 pm
Yup, check change that part where you see the default password.... but of course you need to compile and load into the PIC.
shiyan
Postby rzuan ramlan » Mon Feb 04, 2013 11:49 pm
can u make this program for me ???
seriously i want to buy the program for this passwood door security
rzuan ramlan
Postby akif syahmi » Thu Nov 27, 2014 2:41 pm
can i see the circuit to set up the magnetic lock??? ASAP
akif syahmi
Postby ober » Fri Nov 28, 2014 9:27 am
Go to PR9 page, click on Attachment, check the schematic link.
