DC Brush Motor WIth MD10C and PIC877A problem
Postby Ali » Fri Jan 06, 2012 10:36 am
Dear all,
Hello,
I am new and seeking your kind help.
I am recently running a DC brush motor with MD10C and PIC877A .
How can I control the speed of this motor automatically? When I press SW1, motor does not work but when I press SW2 motor rotates with constant speed.
I want to control the motor by program rather pressing the button SW1/SW2.
Any help will be highly appreciated.
Thank you very much.
As a new user I am just using the sample program from this website as follow:
//   Author            : CYTRON TECHNOLOGIES SDN BHD
//   Project            : SK40C sample code for PIC16F887
//   Project description   : Driving DC brush motor with MD10C
//                    2 mode: (1: Sign-Magnitude PWM)
//                          (2: Locked-Antiphase PWM)
//   include
#include <htc.h>
#include "lcd.h"
#include "system.h"
#include "pwm.h"
//   Configuration
__CONFIG(HS &         // External Crystal at High Speed
       WDTDIS &      // Disable Watchdog Timer.
       PWRTEN &      // Enable Power Up Timer.
       BORDIS &      // Disable Brown Out Reset.
       MCLREN &      // MCLR function is enabled
       LVPDIS);      // Disable Low Voltage Programming.
//   function prototype
void delay_ms(unsigned int ui_value);
void sign_magnitude_pwm(void);
void locked_antip_pwm(void);
void wait_sw1(void);
//   main function
void main(void)
   PORTA = 0;
   PORTB = 0;                     // Clear Port
   PORTC = 0;
   PORTD = 0;
   TRISA = 0b00000000;               // set PORTA as OUTPUT
   TRISB = 0b00000111;               // set PORTB<7:3> as OUTPUT , PORTB<2:0> as INPUT
   TRISC = 0b00000000;               // set PORTC as OUTPUT
   TRISD = 0b00000000;               // set PORTD as OUTPUT
   ANSEL = 0;                     // Set PORTA as Digital I/O
   ANSELH = 0;                   // SET PORTB as DIGITAL I/O for PIC16F887
   lcd_initialize();               // Initialise LCD
   pwm_initialize();               // Initialise PWM1
unsigned char mode = 1;
while (1)
   switch (mode)
      case 1: while (SW1 == 1)
               lcd_clear();
               lcd_putstr("Sign-Magnitude\nPWM");
               wait_sw1();
               if(SW1 == 0) break;
               lcd_clear();
               lcd_putstr("DIR to RA0\nPWM to RC1");
               wait_sw1();
               if(SW1 == 0) break;
               lcd_clear();
               lcd_putstr("Press SW1 when\nReady");
               wait_sw1();
            while (SW1 == 0);
            sign_magnitude_pwm();
            pwm_set_duty_cycle(0);
            break;
      case 2:   DIR = 0;
            while (SW1 == 1)
               lcd_clear();
               lcd_putstr("Locked-Antiphase\nPWM");
               wait_sw1();
               if(SW1 == 0) break;
               lcd_clear();
               lcd_putstr("DIR to RC1\nPWM to RA0");
               wait_sw1();
               if(SW1 == 0) break;
               lcd_clear();
               wait_sw1();
            while (SW1 == 0);
            locked_antip_pwm();
            DIR = 0;
            break;
   if (++mode > 2)             // if SW1 is press, increase the mode number until it is max and loop back
      mode = 1;
* PRIVATE FUNCTION: sign_magnitude_pwm
* PARAMETERS:
* ~ void
* RETURN:
* ~ void
* DESCRIPTIONS:
* MD10C Sign-Magnitude PWM mode
void sign_magnitude_pwm (void)
unsigned int speed;
lcd_clear();
lcd_home();
lcd_putstr("DIR:");
lcd_goto(0x07);
lcd_putstr("PWM:");
lcd_2ndline();
lcd_putstr("Sign-Mag PWM    ");
      lcd_goto(0x04);
      lcd_putstr("1");
      DIR = 1;
      for (speed=350 ; speed<1024 ; speed++)
         delay_ms(10);
         pwm_set_duty_cycle(speed);
         lcd_goto(0xB);
         lcd_bcd(4,speed);
      lcd_goto(0x04);
      lcd_putstr("0");
      DIR = 0;
      for (; speed>350 ; speed--)
         delay_ms(10);
         lcd_goto(0xB);
         lcd_bcd(4,speed);
* PRIVATE FUNCTION: locked_antip_pwm
* PARAMETERS:
* ~ void
* RETURN:
* ~ void
* DESCRIPTIONS:
* MD10C Locked Anti-Phase PWM mode
void locked_antip_pwm (void)
unsigned int speed;
lcd_clear();
lcd_home();
lcd_putstr("DIR:");
lcd_goto(0x07);
lcd_putstr("PWM:");
lcd_2ndline();
lcd_putstr("Locked-Antip PWM");
      lcd_goto(0x04);
      lcd_putstr("1");
      DIR = 1;
      for (speed=1024 ; speed>0 ; speed--)
         delay_ms(10);
         lcd_goto(0xB);
         lcd_bcd(4,speed);
* PRIVATE FUNCTION: delay_ms
* PARAMETERS:
* ~ ui_value   - The period for the delay in miliseconds.
* RETURN:
* ~ void
* DESCRIPTIONS:
* Delay in miliseconds.
   while (ui_value-- > 0) {
      __delay_ms(1);      // macro from HI-TECH compiler which will generate 1ms delay base on value of _XTAL_FREQ in system.h
* PRIVATE FUNCTION: wait_sw1
* PARAMETERS:
* ~ void
* RETURN:
* ~ void
* DESCRIPTIONS:
* wait for switch 1 to be press while have delay
void wait_sw1(void)
   unsigned char i;
   for (i = 0; i < 200; i++)
         if (SW1 == 0)
            return;
         delay_ms(10);
Ali
