RF Remote Control
Fri Feb 03, 2012 1:47 am
by Eddy Ramlin
hello.
as a beginner,by referring to DIY-PR6-A ( Bluetooth remote control), i would like to change BLUETOOTH into RADIO FREQUENCY (RF) to become a ' RF remote control ' and use for home automation especially for lamp and fan. it is possible?
then do you have any suggestion of site or reading material for this, to add my knowledge bout this.
THANK YOU.
Re: RF Remote Control
Fri Feb 03, 2012 7:25 pm
by kl84
If you only need to send command and don't need to read from device, RF module (one way communication) can be used. Take a look at
this diy project from Cytron.
Sat Feb 04, 2012 7:04 pm
by royalstorm7
u can use 433Mhz rf receiver transmitter + PT2262 + PT2272 and microcontroller for total control solution...yes it's fun..
royalstorm7@yahoo.com
Tue Jun 26, 2012 9:43 am
by Eddy Ramlin
royalstorm7 WROTE:u can use 433Mhz rf receiver transmitter + PT2262 + PT2272 and microcontroller for total control solution...yes it's fun..
salam.tq sir for ur suggestion. i have done with PT2262+2272 to control ON and OFF function (as a switch) for fan and lamp but then now i would like to add another function it is speed function for the fan and dimmer for the lamp(if possible) with that i have to change the PIC here i need ur idea or suggestion about the suitable PIC that can be use to perform this task? tq
Tue Jun 26, 2012 9:49 am
by Eddy Ramlin
kl84 WROTE:If you only need to send command and don't need to read from device, RF module (one way communication) can be used. Take a look at
tq and need ur suggestion..it is possible for me to change the function? to add speed function for the fan and dimmer to the lamp(if possible). what kind of PIC can be use? and it is possible for me to use this circuit to perform mine? tq
Thu Jun 28, 2012 11:29 am
by zhenning
Eddy Ramlin WROTE:kl84 WROTE:If you only need to send command and don't need to read from device, RF module (one way communication) can be used. Take a look at
yes , it is possible. depending on what is the size of your code and any other extra hardware functions such as 2 uart, any PIC would do.
