PR29
Re: PR29
Postby Suria » Sat Mar 31, 2012 11:39 pm
robosang wrote:Why don verify the Microcontroller is working first :) Is there any simple LED blinking verification?
how to verify the microcontroller? sorry :(
Suria
Re: PR29
Postby robosang » Thu Apr 05, 2012 10:43 am
Just write a simple LED blinking, add a LED at any pin which is not in use. Load the program then you are done! Don tell me you don know how to write simple LED blinking 8-)
Re: PR29
Postby mark » Sat Apr 07, 2012 11:03 am
I sent it back to Cytron. They replaced a new LCD and reprogrammed the IC and it works just fine on the PCB given. I am not sure whether it will work again then I put it on breadboard.
mark
Re: PR29
Postby ABSF » Sat Apr 07, 2012 11:19 am
mark wrote:I sent it back to Cytron. They replaced a new LCD and reprogrammed the IC and it works just fine on the PCB given. I am not sure whether it will work again then I put it on breadboard.
Congratulations! you finally had it working.......So there's nothing wrong with the FPU.
What about the PCB you made yourself? Did you try to make use of it? Or you havent made it yet.. :roll:
Re: PR29
Postby mark » Fri Apr 27, 2012 11:05 pm
i finally had it working on the board by cytron but when i fix everything on breadboard, it doesnt work because of the lcd that i bought outside doesn't seem to work on that. i've tried all my might doing it but unfortunately, i have to change my project because its not working on the breadboard. Even on the board by cytron itself, sometimes its working, sometimes its not working. i'll solve all that later, i'll need to finish the new project first because i need to graduate by this semester. thanks a lot guys! :D
mark
Re: PR29
Postby ABSF » Sat Apr 28, 2012 6:12 am
mark wrote: Even on the board by cytron itself, sometimes its working, sometimes its not working. i'll solve all that later
Intermittent faults are always hard to solve... :mrgreen:
mark wrote: i'll need to finish the new project first because i need to graduate by this semester. thanks a lot guys!
Wish you best of luck in your project and finished it within time. ;)
Re: PR29
Postby CoronaMee » Tue Feb 18, 2014 10:11 am
i want to ask how to burn pic correctly....i already burn it with hex file but it still no output on lcd...are the coding pr29 correct?and i want to ask about using mplab...do you can give me a video about burn the pic file using mplab...
CoronaMee
Re: PR29
Postby ober » Tue Feb 18, 2014 12:26 pm
CoronaMee wrote:i want to ask how to burn pic correctly....i already burn it with hex file but it still no output on lcd...are the coding pr29 correct?and i want to ask about using mplab...do you can give me a video about burn the pic file using mplab...
All DIY project example codes are being tested in actual hardware before it is being released :) It is not flawless, but it works.
If you look carefully at the PR29's product page, you are able to get a link to the tutorial that show method to develop project in MPLAB IDE and burn the hex code to PIC: http://tutorial.cytron.com.my/2012/07/03/getting-started-with-mplabide/
The video:
Re: PR29
Postby CoronaMee » Tue Feb 18, 2014 1:18 pm
i have already burn pic and it work properly...but when i switch on my project and want to reset admin, lcd keep showing resetting admin and not happen change...my project not show the admin login and user login...
CoronaMee
Re: PR29
Postby gadgetng » Tue Feb 18, 2014 6:03 pm
CoronaMee wrote:i have already burn pic and it work properly...but when i switch on my project and want to reset admin, lcd keep showing resetting admin and not happen change...my project not show the admin login and user login...
Hmm.. after display the resetting admin, it should guide u to add the new admin. If it is hang on that display, i am suspecting the connection between fingerprint reader and the pcb. Please double check again.
gadgetng
