PR11
PR11
Postby ken_257 » Fri Apr 13, 2012 4:43 pm
HI all ,
i had copy the board and do it new one, after all done, load the program to IC done. when i turn on the circuit one red and green LED is turn and one fan turn on, but the display LCD is nothing just show the black box at uper row only .... any people can help me ...
i had check all connection with the original board, all is correct ....
thank
ken_257
Re: PR11
Postby mec » Fri Apr 13, 2012 5:10 pm
So you got a original PR11 board which is working? If yes, you can just verify the LCD first by changing the LCD to the working board. If the LCD is working, then should be connection problem.
Last time i have to get a new LCD after damaging my previous one.
mec
Re: PR11
Postby ken_257 » Fri Apr 13, 2012 5:44 pm
the original board is blank, i use all component install at my board already , so that i need to buy 1 set component and install again ...
ken_257
Re: PR11
Postby kl84 » Mon Apr 16, 2012 8:32 am
Did u tuned the variable resistor?
kl84
