PR26 - game contoller not detected
Posted: Fri Oct 19, 2012 5:08 pm
It looks like I have done everything right but my game controller is not detected Linux/Windows 7/Mac. Nothing pops up like it is trying to install something and fails, just does nothing...
Here is my diagnostic info:
* Green PWR led is on (power getting through from USB)
* I can program, read, erase, read (zeros), program, read (program) and verify (red light flashes)
* Once suspicous thing is the message about power
All the jumpers are there and there appears to be no shorts - any suggests on what it could be?
Below shows the code builds ok and the versions I use - any help appreciated!
Paul
- CODE: SELECT_ALL_CODE
Verifying Target
PIC18F2550 found (Rev 0x7)
Verifying Program Memory (0x0 - 0x7FFF)
Verifying EEPROM Memory (0x0 - 0xFF)
Verifying User ID Memory
Verifying Configuration Memory
PICkit 2 Ready
Found PICkit 2 - Operating System Version 2.32.0
PICkit 2 Unit ID = UIC00B V1.0
[b]Target power not detected - Powering from PICkit 2 ( 5.00V)[/b]
PICkit 2 Ready
Paul
Release build of project `D:\max\GameController\MaxGameController\MaxGameController.mcp' started.
Language tool versions: mpasmwin.exe v5.46, mplink.exe v4.44, mcc18.exe v3.43, mplib.exe v4.44
Fri Oct 19 20:06:40 2012
Clean: Deleted file "D:\max\GameController\MaxGameController\usb_device.o".
Clean: Deleted file "D:\max\GameController\MaxGameController\usb_function_hid.o".
Clean: Deleted file "D:\max\GameController\MaxGameController\main.o".
Clean: Deleted file "D:\max\GameController\MaxGameController\usb_descriptors.o".
Clean: Deleted file "D:\max\GameController\MaxGameController\MaxGameController.cof".
Clean: Deleted file "D:\max\GameController\MaxGameController\MaxGameController.hex".
Clean: Done.
Executing: "C:\Program Files (x86)\Microchip\mplabc18\v3.43\bin\mcc18.exe" -p=18F2550 "D:\max\GameController\Source Code PR26\Source Code PR26\usb_device.c" -fo="usb_device.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\Program Files (x86)\Microchip\mplabc18\v3.43\bin\mcc18.exe" -p=18F2550 "D:\max\GameController\Source Code PR26\Source Code PR26\usb_function_hid.c" -fo="usb_function_hid.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\Program Files (x86)\Microchip\mplabc18\v3.43\bin\mcc18.exe" -p=18F2550 "D:\max\GameController\Source Code PR26\Source Code PR26\main.c" -fo="main.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\Program Files (x86)\Microchip\mplabc18\v3.43\bin\mcc18.exe" -p=18F2550 "D:\max\GameController\Source Code PR26\Source Code PR26\usb_descriptors.c" -fo="usb_descriptors.o" -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Executing: "C:\Program Files (x86)\Microchip\mplabc18\v3.43\bin\mplink.exe" /p18F2550 "..\Source Code PR26\Source Code PR26\rm18f2550 - HID Bootload.lkr" "usb_device.o" "usb_function_hid.o" "main.o" "usb_descriptors.o" /u_CRUNTIME /z__MPLAB_BUILD=1 /o"MaxGameController.cof" /M"MaxGameController.map" /W
MPLINK 4.44, Linker
Device Database Version 1.9
Copyright (c) 1998-2011 Microchip Technology Inc.
Errors : 0
MP2HEX 4.44, COFF to HEX File Converter
Errors : 0
Loaded D:\max\GameController\MaxGameController\MaxGameController.cof.
Release build of project `D:\max\GameController\MaxGameController\MaxGameController.mcp' succeeded.
Fri Oct 19 20:06:44 2012
BUILD SUCCEEDED
