help me on pr23
help me on pr23
Postby ameerul9906 » Sat Nov 10, 2012 6:29 pm
i've bought this pr23 and assembled it... for mode line follower, it works perfectly.. but for skps mode, the motor didnt even run.. but the blue led indicator is responding as i pressed buttons on the ps2 joystick.. help..
ameerul9906
Re: help me on pr23
Postby robosang » Sat Nov 10, 2012 6:41 pm
Share a clear photo on the board.
This is one of Cytron DIY project right? Have you check their document clearly? I have seen people using it and Cytron always bring it during exhibition, it should be working fine.
Re: help me on pr23
Postby gadgetng » Tue Nov 13, 2012 2:04 pm
ameerul9906 WROTE:i've bought this pr23 and assembled it... for mode line follower, it works perfectly.. but for skps mode, the motor didnt even run.. but the blue led indicator is responding as i pressed buttons on the ps2 joystick.. help..
Then i guess you have to check on the SKPS connection. Is the soldering ok? Is the program loaded with SKPS-PS2 function? Can't help u much as i haven't play PR23 before.
gadgetng
Re: help me on pr23
Postby ober » Wed Nov 14, 2012 9:28 am
Have you check the jumper to move the UART pin, either for Ultrasonic or normal UART communication? It is located right of the PCB board near the right wheel. You will need to make sure the jumper is at "COM". Try it.
